I bought my soundcore spirit pro about a month ago on Amazon and it won’t turn on after a sweaty workout. It charges fine but I think the power button is broken. Is there anyway I can fix this or get a replacement?
Soundcore spirit pro won't turn on
You don’t have the option to returned with Amazon?
Try Anker customer service.
Those have sweatguard tech, so the fact you had a sweaty workout should not be the reason or cause of them not turning on. You said they charge fine? Are they fully charged when you try to turn them in? Are they still plugged in when trying to turn them on?
As tank said, a sweaty workout wouldn’t have broken these.
Make sure you’re using a charging source that has trickle charge? Without a trickle charge, the product may think it’s charged, but it isn’t, it’s a false positive!
