Hello, the speakers on my Soundcore Select have blown out, and I’d like to find replacements for them. Would you know what kind of speakers are you used. My select is past the warranty period and I haven’t had any replies from Anker/Soundcore so far
Soundcore Select replacement speakers
Did you contact the support?
Otherwise, is there any model number etc to be found on the speaker.
I am sure they are using “normal” speakers which can be bought and replaced.
