Not sure there is an issue here, but I would have expected the light to be solid after charging for that long. Once unplugged, the lights are all solid, but trying to figure out if this is normal behavior. The earbuds themselves show fully charged when paired with my phone though…
Soundcore NEO - 3rd Case lights flashing after 12 hours charging
I would recommend emailing anker directly about your issue at support@anker.com
They should resolve your issue…
Thanks! I will do that!!
It could just be an issue where you need to reset the charging case. Take a paperclip or something similar and short the two pins on the left side where the left earbud goes. And see if it does this still. Ideally the lights go off once fully charged, my case generally is fully charged after an hour or two…
