Soundcore Motion+ Deal for $84.99
Buy here
With code HOME3116
Thanks for sharing!
That’s a great deal @Shenoy
Would love to hear this in the flesh, as wouldn’t mind an upgrade to the Boost 20w I have.
I think @Chiquinho has one.
Yes I have one, Paul.
I wrote a review here some time ago.
And I was asked about that speaker at soundcore’s forum as well.
Needs a while to get your ears used to, because of the tweeters.
I started to use the eq first to reduce trebles.
But the more you listen to, the more you “undo” that.
Fine is USB-C.
But this speaker is not for traveling and carrying around with luggage.
Too bulky and too heavy, same as ZERO.
At home its perfect, same as ZERO!
Ah, I was sure it was you who had one Franz.
I prefer a a little more bass in music but always a good balance of sound.
@paulstevenewing @Chiquinho I don’t have both Motion+ or Zero… may be I will plan on getting the motion+ myself some time
The best solution I can offer you, Paul
Go for 2 Flares (normal ones or + or 2) and connect those in Stereo mode.
At the moment I am using mine and can tell you about the traffic jams in Lisbon.
I have been considering the Flare from the original.
I keep an eye on the price on Amazon, when there is a sensible reduction I might buy one…or two
I have 2 Flare Minis and these work awesome in Stereo Mode,
Soon, will have Flare 2, pair. Will test these on Stereo Mode and have a review for it
Zero is a very special one.
I never got a chance to compare with Trance or Rave.
So I can not tell you more about. Sorry.
Others could -> testers!
thank you @Chiquinho your insight is invaluable !
i think there have been some of good reviews on Trance here and Soundcore Collective,
I like Motion+ for its looks and style, dont have this variation of speaker from Soundcore, so next on my list.
Have a small collection of Soundcore speakers myself SoundCore Nano (see the Capital C ) , Icon Mini, Flare Minis, Flare 2, Rave Mini
Flare 2 will be my first non-mini speaker from Soundcore
