I received the Soundcore Motion B Portable Bluetooth Speaker as sample for test
I am very happy to have received it, it has filled my expectations.
the speaker comes in a box with an attractive illustrative image, inside its accessories and the speaker.
I thought it would be a large speaker, but upon receiving it I was impressed by its size, it is small, not so small, but it fits perfectly in my hand, its weight is very light, details that I loved!
publicly speaking, the speaker promises 12-Hour Playtime, I have connected it to the charger until the battery is fully charged, so far I have been using it for six hours and it is still with the battery charged, so I will continue using it and controlling the time of exhaustion of the battery.
also, they promote that it is water proof, it has a cover of an insulating material, which apparently is what protects the device completely, so I have splashed water on it, and it was not damaged after turning it on.
then I thought, with a small size, would the audio have enough power?
I turned up the volume to the maximum and was impressed! My God, what a great speaker! the sound was powerful! Awesome! I could not believe how such a small speaker had such a strong and good sound, that comparing it with another player from a different brand (iclever) even bigger than it sounds at a lower power !!
I can only say that the Soundcore Motion B Portable Bluetooth Speaker is the best speaker in its size and quality I’ve had so far !!!
If you are looking for something light and powerful, think it over!
I have a single image on my cell phone at this precise moment, I will upload it right now, I promise that in the course of the day I will update this post and upload more photos of the speaker.
