Have just received a Soundcore mini, not sure how and what to connect to in order to download music to it! ( I am a not technical senior citizen). Need a few basic instructions please. Many thanks. Janet
Soundcore mini initial set up and use
Hi @janet_airey
Great speaker
You cant download direct to the speaker as far as i can see.
You can use a MicroSD card and put music onto that to playback through the speaker.
You can not download music to the speaker.
You can connect the speaker via Bluetooth to your phone, tablet or computer.
On these connected devices you can use the same sources for you music you always use.
Yes @paulstevenewing told you about inserting a MicroSD,
I forgot this type of speaker has this feature.
This is an option of course.
If there are more issues please ask, we are here to help.
Enjoy the little speaker and your Sunday.
Many thanks for your responses, will go ahead with the advice. Janet
You can only solution in the Q&A category. Moderator can move category then can solution.
Of course.
You know, i rarely look at the categories.
Me too ,it doesn’t matter for me.
If there is somebody who needs an answer and I can help
I don’t mind the category.
