Recently bought a Q20 but discovered it makes a lot of white noise, even humming, when using the aux audio jack cable. When I switch to bluetooth, the white noise disappears.
The problem is that I need to use the aux cable to connect my Q20 to my computer when on Teams: when I use BlueTooth, I cannot hear all the sound tracks coming from my computer. For instance, when I am on Teams and I need to watch a video at the same time, I can’t hear the sound from the video, only the sound coming from Teams. When I plug the aux cable, I can hear both the sound from Teams and from my video. But then, there is a lot of static/white noise.
Maybe there is a fix to make it possible to hear all tracks through BlueTooth? That would solve part of the issue.
The remaining issue is to fix the static/white noise when using the aux cable. I guess this is not normal functioning, right?
