Thanks you.
Soundcore life Q20 not turning on
I have a problem where my SoundCore Q20 headphones wonât turn on or have any sign of it turning on when I press and hold the power button. Iâve charged it before and Iâve let it do that for a whole day and still, it does the same thing. When I charge it, the red light appears like normal, but when I try to turn it on, itâs like I didnât even press a button. Could I please get an answer towards this?
Edit: Iâve even tried to reset it by holding the power and volume up button for 5 seconds and it still acted like I didnât even press a button.
Are the earphones under warranty?
If so you should contact the support.
What about contact spray on / in the on/off button.
May be this could help.
Give it a try.
I remember this because I was successful with our old washer.
Same problem like yours.
Contact spray in /on the on/off button helped.
Its the best way to clean contacts and electrical connections.
Appears dead, youâve tried all weâd normally recommend.
Hopefully you bought it in a manner to get warranty. Email service@soundcore.com attach proof of purchase, photos showing not damaged, and description of fault. My last warranty issue I made a video showing me trying to operate it and send link to it. I got a replacement 3 days later.
Normally they ask for unit to be returned but if you can show it is dead then they donât always ask for a return (my last warranty the video showed it clearly dead)
Warranty is 18 months in most countries.
Hopefully you didnât buy from AliExpressâŠ
They sent me 3 different sets and they all had exactly the same problem. Obviously a design flaw. I have given up but would be fascinated if anyone has a solution!
This isnât âunusualâ as they say, itâs a design flaw and it will self-fix, the first time this happened after a couple of days my headphones just turned on and then worked fine, but happens still every now and then⊠I doubt Iâll be buying another Anker product but it would be good to work out how to fix the issue. If Anker admitted it was an issue and provided a solution, it would be good for all parties.
Thatâs software.
A black box.
ones creates an input for a program, doesnât work.
One creates absolutely the same input for a second test, it works.
I donât know any programmer who created a program
which worked perfectly after eliminating the usual syntax errors.
But to say it after working 50 years in the informatics science.
Itâs not an âexact scienceâ
Thatâs only true of stateless software where the only data is the input.
The higher end / newer Soundcore products are stateful, they store previous settings. As such they can be in a different state when receiving the same input.
Complexity causes failure.
Outlining oneâs CV doesnât help anyone.
Hereâs the solution everyone else, disconnect the Bluetooth and wait for the unit to shutdown on itâs own, plug it in and charge, unplug and turn on.
I have exactly the same issue! So frustrating. I purchased these to be noise cancelling and they just wonât turn on. I have sent an email to support but I purchased these a while ago and didnât use them because no travel during pandemic (these are just for the plane, I donât use headphones any other time).
Seems to be a âtotal dischargeâ
No one should do that.
Keep them on the charger for a long time and âprayâ.
The ON/OFF button is in the middle of the ± volume. The NC (noise cancellation) may look like the ON button if you donât look close or read instructions⊠My former pair of headphones (JBL) have the ON/OFF button exactly where the NC is located on my pairâŠ
Guess why I ended up here lol, I was clicking on the wrong buttonâŠ
Hope this helps.
I have exactly the same problem. They wonât turn on any more. Ok for wired connection, but useless for anything else. Did anyone else have a solution? I really needed them today on a plane. They are out of warranty now
I had the same issue wouldnât turn on but would light up if plugged in. No warranty left on them if your mechanically sound enough to take them apart, I have instructions.
Take the ear pad off the left ear headphone
Remove the four screws holding the speaker to the housing
inside the housing where the battery is there is a small two pin plug-in
Mine was simply unplugged
