**Hello. **
**I was using my Q10 perfectly until today. **
now it can connect to nor my laptop neither to my iphone.
**anyone can help me about that? **
Thanks.
**Hello. **
Thanks.
Make sure the headphones are fully charged.
Then try a connection via Aux cable.
If this works, I would do a reset…
You may search the forum for the “how to”.
I dont have those, sorry!
charged full.
works with aux cable.
reset.
and same issue.
Try this: delete the bt list from your iphone and try a new connection.
If this not works - > service:
service@soundcore.com
How did you reset the Soundcore Life Q10?
Hope you followed the below, if not try and let us know.
After reset, try to delete all pairing details on Laptop and iPhone.
Try to pair with one device at a time - iphone or Laptop
Do keep us posted. Also write to Soundcore Support
Turn the computer off and then back on
hey i bought soundcore life q10. I got a REAL BIG ISSUE, while i am using my headphone on platforms like MS TEAMS, GOOGLE MEET etc, for a meeting call, after sometime it stops giving the output audio(instead gives a low quirky audio sound) even though it shows connected.
PLEASE provide a SOLUTION.
I have exactly the same issue.
I am facing the same issue. @ [Soundcore Support], please help
To get to official support send email to
If you need to process warranty then proof of purchase, serial number and description of problems and what you’ve already done to attempt to address (to bypass the delay while they tell you to)
To get like-user help then
