Hello. My liberty neo right ear bud has no sound. Has lights. And the Left side has sound. I tried resetting it, but no use. Both buds worked fine. And all of a sudden the right does not work. Any help will be appropriated.
Soundcore Liberty neo
Plenty of existing threads, look for ideas here first
I would try to reset them and reconnect them. I am assuming the rt one is charging. If it still has issues, you can contact service@soundcore.com for additional help and support.
Tried your suggestion, but I am having the same issue. Sent off a mail to soundcore support. Awaiting response.
