I have 2 sets of these headphones and for one of them the right earbud isn’t working and for the other one the left earbud isn’t working is there anyway I can pair these 2 together to keep the good ones working?
Soundcore liberty lite pairing
What you need to do is go through a proper reset of the earbuds so they pair and work properly with the set they belong to. But to answer your question, no it’s not possible to pair two different sets together to make 1 working pair.
Actually I was able to connect them together finally by putting both working ones in the case and taking them out double click them both simultaneously and then connect to my phone. Thanks for the help!
