I’m having a problem when using these buds on a plane. They were fully charged before I left home. But after I pass from the security procedure at the airport and get on the plane I turn on the buds and the battery is 20%. It happened twice already. When I use them at home I never have this problem. It always happen when I am on a plane. Anyone have this problem? Could it be that the security scanning devices at the airport effecting the buds?
Soundcore liberty air on a plane
It could be that when your moving about the earbuds get jostled loose in the case and turn on and pair to your phone. So when you use them they are already drained.
- Make sure the charging case has enough power (at least two white indicators on the case). Note: after the earbuds are fully charged, the steady white light on the earbuds will shut off.
- Take the earbuds out of the case and see if a flashing white light comes on. If it doesn’t, try manually pressing the button or touchpad of the earbuds to power them on.
- Try to use a terrycloth/cotton swab with a bit of alcohol to clean the contact pins both in the charging case and on earbuds to ensure a better connection.
Be advised that the power will be steady blue when it is fully charged.
Please note that playtime varies according to volume level and audio content played on the headphones
