Soundcore Liberty air issue
hey i bought Soundcore Liberty air few days ago, its a very nice earbud. i am enjoying it. but the charging case is a plastic, my little brother touched with oily hand, it really worse now, can anyone give me a better idea , how can i clean the oils from charging case, please help.
I use baby wipes or hand wipes to clean the case…
What type of oil? You may want to contact support and check and see what cleaning products are safe to use on the case. Certain kind of plastics can be damaged by cleaning chemicals.
service@soundcore.com
normal cooking oil, oil in outside of case not in inside.
Ooh, I was thinking like hand oils (sweat). A hand wipe might still work… it’s worth a try :man_shrugging:
Depending on the finish of the case, glass wipes or rubbing alcohol is what I normally use for cleaning…
Perhaps try using a mild mixture (in water not neat) of washing up liquid, with a lightly damp cloth?
It’s important to note that depending on which case you have for Liberty Air, it will have different finishes.
What @ndalby :arrow_heading_up: said
The case on liberty air (black) is kind of a fingerprint magnet…
I have been considering decorating the case with tiny rhinestones or if anybody has and more manly suggestion it would be appreciated :grin: it really isn’t a huge deal but I kind of have OCD when it comes to things like this and would prefer the case did not attract smudges and light scratches.
I wonder if it could be airbrushed with other colors, and then a new finish :thinking:
That’s a good idea I do have some cool colors laying around from an old RC build.
It would need to be sanded and sealed after I apply the chosen color :thinking:
If you do it don’t forgot to upload pictures :grin:
Maybe I’ll give it a whack this weekend.
When I do I’ll be sure to take lots of pictures.
