Soundcore liberty air 2 - help please
Hi just got my anker soundcore liberty air 2 and the right side is not producing sounds. I can only hear the off and on sound.
Anyone knows how to solve this?
Hi, @sab1, here is a video tutorial that you may find helpful:
If this doesn’t work, please contact service@soundcore.com.
I have same exact issue. Did reset work for you? Thanks!
Hi @tomasdiazv, if the above reset procedure does not work for you, please reach out to service@soundcore.com for additional assistance. Thanks!
