Soundcore Liberty Air 2 custom EQ settings
Hey guys! Just bought a pair of Liberty Air 2 and they are fantastic in term of comfort, look and call quality, but I’m in a little struggle with a custom EQ settings. I tried different presets and also tried HearID. All of them doesn’t work for me.
This is the closest I got for me to be good, but it is still sounds kinda “underwaterish”, “from a bucket”. I dont know how to describe it well…
I want a clear sound, without too much echo and without too much bass.
I know that sound is highly subjective term, but can you guys with Liberty Air 2 upload screenshots with your custom presets? Maybe one of them will be good for me.
Much appreciated!
You should try an eq without that app.
There are many players around offering eqs.
May be you find a better adjustment.
Play around!
The only good thing about Soundcore App custom EQ is the EQ gets set into the Headset and is applicable to any audio that plays out through it (at least that’s what I think)
There are lot of equalizers apps on appstores (iOS AND Google), Boom is my favorite on iOS that I use!
Different players, different users, different speakers, different eq.
Bildschirmfoto
I personally think that the best overall sound comes from the “original preset”. I use the custom EQ, but I adjust it slightly for every song I listen to.
If I’m going to listen to music while I work or something, then I set it to the original preset
More adjusting than listening! :rofl:
I’m super happy with this set, took me a while to play around with it. Keep in mind I mostly listen to Rock, so its more acustomed to that.
After a while I got +/- what I wanted using two different eq’s at the same time: Soundcore app EQ and YouTube Music EQ. Because I’m only using YTM for audio surfing I don’t wanna use third party EQ apps or music players. And I’m listening several music genres (metalcore, synthwave, witch house) so I want a universal EQ preset.
Here’s what i came to:
For me it sounds mostly neutral but with lesser bass and more clarity. Exactly what I needed.
Thanks everybody for your replies!
I tried your setting. It’s so good and it become my default setting! I guess it means we have the same sounds preference haha,Thank you!
