Soundcore liberty 2 pro with PC use button?
i have Soundcore liberty 2 pro and i usually use it in PC.
but i cant use the button to pause or play next music in PC. so is there anyway to use button on this earphone with PC (windows 10) ? or Is there any driver i need to install to do it?
So right now soundcore app is an android or ios app and not compatible with a pc right now.
With that said, I remember people creating an android emulator that if I remember right can be emulated on ios or a pc.
I would say not to use until you do sufficient research on how it would work on a pc.
