Soundcore Liberty 2 pro only one is working
Hey guys, recently my left earbud stopped working properly. There’s only a little bit of sound while the right one works just perfectly.
I tried to reset them, to connect them over and over again but the problem still remains.
Can anybody help me?
Did you try to remove the earbuds from the bt list of your item and connect these again. This helps sometimes.
Otherwise you should contact the support.
Take some peroxide and a qtip and clean the earbuds. Could be a earwax build up.
Can you check is getting charged? Maybe it’s just dead and it’s not fully connecting in the case therefore not getting any power
