Soundcore Gaming Studio (Anker Audio 7.1) Does Not Work !
Hello, i have an Anker Strike 3. Suddenly the Soundcore GAMING STUDIO (Anker Audio 7.1) software disappeared. I am using Windows 10 Home Edition (updated regularly). I downloaded the software again and tried to reinstall the software but nothings changed. I tried also running with admin previliges again nothing happened. Anker Audio 7.1 software did not opened. I checked also windows reg and nothings happened in registry records. How can i run it again ? Please help.
I dont know if WIN10 still is using these registry file.
If so, you should delete the “traces” of that software and install it again.
Sometimes there are relics left after deleting a program which are causing troubles.
But I am not a WIN user anymore now for many years, may be other members have better ideas.
Try restarting your computer, wr had this issue and restarting the computer allowed the software to work properly
thanks for all, i solved my problem. Here is the solution for others; install and run MSERT.exe, select full scan module, then restart the computer, thats all.
