Soundcore flare +
So I just bought the soundcore flare + and it wont even turn on I’ve held the power button for 3 seconds like it sais to do I tried plugging in an aux cord… tried bluetooth… tried plugging in my charger said it had a full charge… idk in stumped and very frustrated all i wanted to do was have a little speaker loud enough to hear over a bunch of work equipment🤦‍♂️
Are you sure its really fully charged?
if so, it would be the best to contact the support.
service@soundcore.com
But dont forget, its weekend, so the answer might take a while.
@broi Have your tried charging the Flare+ using a different cable and wall adapter to ensure its not a cable/power adapter issue preventing a correct and full charge?
If you have it would be best to reach out to service@soundcore.com as @Chiquinho suggested.
