Soundcore Flare+
I need some help, I am trying to pair the speaker to my Sony X800G TV however the tv can’t find the bluetooth ? Anyone else having this problem…? Is it because the Flare+ is incompatible with the tv…I was researching that bluetooth devices should work with smart tvs.
I would make sure the tv’s firmware is up to date and if that didn’t work I would reset the tv.
A reset of that TV might be really helpful.
Have you tried to connect the speaker with other devices via bt ?
It is up to date. I reset the tv still, it didn’t pick up the bluetooth lol mind you, it is a new 2019 tv :skull: I guess I will try other wireless speakers and headset to see if it works too. It might be bc Soundcore Flare+ not compatible with Sony Tvs
It is possible but I wouldn’t think that is the problem. If I were you I would contact sony for advice on pairing bluetooth devices.
According to the specs for the TV it only supports mouse/keyboard low energy devices
Doesnt look like BT speakers are supported, and thats the same regardless of TV size
Thank you so much! I actually contacted Sony and were able to figure out the situation with BT. Only works via Aux cord lol.
If you want to use bluetooth speakers or headphones with your tv, you can through the aux port. You just need a Bluetooth reciever, I use one on my tv myself. This is one I would recommend.
https://www.amazon.com/dp/B07H5C2BQX/
