Soundcore Flare+ not turning on after firmware update
So I recently updated the firmware of my Soundcore Flare+ to the latest (A3161_Soundcore Flare V2.52-201903). After the firmware update, I realized that it wouldn’t turn on. Upon pressing the power button, the speaker lets out a sound I can only describe as a squeak. During this, the bluetooth logo flashes for half a second. If I hold the power button, the power, bluetooth, lights, and bass icons consecutively light up in that order. Any way to fix this?
Try a reset (seek for the way to do here at the forum) if this is not working you should contact the support.
By the way, was this firmware update really successful?
May be you should do this again.
I agree with @Chiquinho as it sounds like the firmware update did not install fully. You could try updating the firmware again or reach out to service@soundcore.com for further assistance. Thanks!
Yup, running the firmware update a second time seems to have worked. Thank you!
Great! :wink:
