My soundcore flare plus will not even show up on my iphone xr as a device to pair with, ive never paired this speaker to this phone before and i can not get it to show up, has anyone else had this issue?
Soundcore flare+ bluetooth issues
Have you tried pressing the bluetooth button on the speaker so it goes I to pairing mode?
Try to follow these
a. Check to ensure your device’s Bluetooth setting is enabled. Turn OFF and then turn ON BT on your iphone
b. Make sure your phone is within 3ft of the speaker.
c. Delete the pairing record on your device then try to re-pair.
Never encountered this issue before. Hope you can pair it again
