Soundcore Flare 2 connection issue
Soundcore Flare 2 pairs fine and stays connected BUT once you disconnect it and leave home and come back (speaker is plugged in so it stays powered on while I’m not using it) it will not connect again. I can see the device in my Bluetooth list and it cannot connect. Then when I power off the speaker and power it on again, it will connect again. I don’t have this issue with Soundcore Flare + or any other Anker or any bluetooth speaker. This is the 2nd Flare 2 as well that has same issue as the 1st. I hard reset a bunch of times but not fixed. And Anker support is useless as there is no fix and only option is to send it in for a replacement. The replacement I have has same issue.
Any have this issue or a fix? I have a Samsung Galaxy S10e.
