So I recently bought a new pair of Soundcore Space NC’s and unfortunately one of the first things I noticed was the fact that they made a pop and hissing sound (not hissing or white noise from the NC being active) whenever I did things such as open apps on my device. What I found was that when “Touch Sounds” were activated on my Note 9 every time did things that were supposed to give sound feedback it made the annoying pop and faint hissing sound completely in sync with my presses. It wasn’t my device either, I tried it on my Dad’s Note 9, my Mum’s Pixel 3 XL and my iPad Pro 10.5, it happened with all three.Then I tried my Dad’s pair of Sony WH-CH500 with my Note 9 and the sound feedback or “Touch Sounds” played perfectly with no popping or hissing. So instantly I thought I had a faulty pair, so I got on a Soundcore live chat and got sent another pair the following few days.
But nope, they had the exact same issue too. While kind of disappointed, I was curious too since it couldn’t have been a defect with my two pairs of Soundcore Space NC’s. So I tried them wired, they worked perfectly. And I also have a Soundcore Boost, therefore I tried it with that. To my surprise there was the exact same issue which leads me to believe there must be an issue with the Bluetooth Firmware inside of some/all Soundcore products? I’ve looked to see if there are others with the same issue but surprisingly not (if you have experienced this issue please let me know).
I hope the Soundcore Space NC’s firmware can be updated too in the future, because it’s definitely not a hardware issue and as of right now you can’t.
P.S
- I did update the Soundcore Boosts firmware to 1.95 and the issue was still present.
- I made a reddit post on r/anker prior to this in search of a fix or explanation as to why this is happening: https://www.reddit.com/r/anker/comments/aaxt1v/soundcore_space_nc_weird_issue/
