I bought anker soundcore boost last month. It was working well but recently speaker got some serious issue.
While listening to music suddenly speaker makes a cracking sound and turns off automatically. then after turning it ON can listen to music for another few minutes and same thing happens again…
Any solution?
Soundcore boost malfunction
This seems to be a failure of the speaker.
As your speaker is in the warranty period you should contact the support.
A help for them is to create a short video incl. the “cracking sound”.
They will help you of course.
If you email support with your serial number and your Amazon order number and explain to them what’s happening they’ll soon sort a new one out for you.
The email is support@anker.com
