So I was debating between buying the soundcore spirit x or the soundcore arcs. I have an iPhone so I was looking for Bluetooth headphones with the aac codec. Do the arcs have aac like the spirits do? Also, is the difference in comfort between the spirit x and the arcs a big difference?
Soundcore Arc vs Spirit X
You can read my review/comparison between the two Here
I can say after having and using both, each one has its benefits. If you wear glasses with thick frames, the arc offers a bit more comfort, otherwise the spirit x works just as good.
Thanks for your reply. Do you happen to know if the arcs support the aac codec that iPhones use? Supposedly it is a huge deal when it comes to the audio quality that the headphones provide.
Thanks for your help!
