Soundcore 2 Portable Bluetooth Speaker
I need a new charging cable which one would work with the Soundcore 2 Portable Bluetooth Speaker?
Anker Micro USB Cable here works well.
Also didn’t the Soundcore speaker come with a Micro-USB cable?
Any micro USB cable should work
yes it did but it bent and doesn’t stay into the speaker.
Ok thanks guys for your help!!
You can use every USB - USB micro cable.
There is no need to get a special one.
Normally there are many around in the house :smiley:
Thanks and I did find one laying around the house…
