I’m having a lot of problems with the SoundCore 2 speaker bluetooth device switching. Anyone have an issue where you cannot change what device is connected to the soundcore2?
I can bluetooth pair it to all of my devices fine, but if I ever want to switch which device the speaker is connected to, the speaker will not connect to that other device even if I’ve previously paired the speaker to it.
I have tried many times, including turning off bluetooth on the device I’m “leaving” before trying to connect to the new device.
The only way I can ever switch which device the soundcore is connected with is to either do a “fresh pair” (1st time Pair) or to go into bluetooth settings on that device and tell it to “forget” the soundcore 2 , then re-do a fresh pairing to the speaker.
I’ve searched on amazon and this forum but don’t see anyone else describing a similar problem… any ideas?
[Dis-regarding this issue… I like the sound quality a lot and the fact that its waterproof, attractive design, etc. This issue kind of makes the speaker way more trouble than its worth though!]
