Hi,
I’m encountering a strange issue with a pair of Soundbuds Tag earphones and would be grateful for any suggestions from the forum. The earbuds are paired to a Oneplus 3T (Android 8.0.0, Oxygen OS 5.0.1) and when I’m using them at home they work fine, no stuttering or loss of sound.
As soon as I try to use them outside the house, the sound starts to stutter and jump, and then eventually drops out. I initially wondered whether this was data/connection related, but it does the same with both listening to things saved on the device (e.g. downloaded podcasts), or streaming music from Spotify. It happens within a few metres of leaving the house if I’ve started something playing before I leave. When I come back through the door I usually hear the ‘beep’ like the earbuds have re-connected to the phone, and then the sound will come back to normal, although the bluetooth seems to stay paired throughout on the phone.
I’m going to try and pair them with a different phone later and see if the same issue arises, but in the interim has anyone got any suggestions of settings to change or things to try on my own device?
Thanks
