Good product but if I use with iphone (6s) using voice call the iphone display the voice control blu screen, wait for command and after the ‘call abc’ return to home screen, no error, no answer and no call…any help for me?
Soundbuds lite
Could you please try restarting your phone and see if the same issues happens? It’s possible that Siri is hanging, so rebooting should help.
I dont use siri but simple ‘voice call’ using normal headset and pressing the call button no problems, but with bluetooth sound lite the blue screen appear, but after the command the voice call exit, no command executed, with siri work fine!
…any little suggestion…
