Hey guys I need help with an issue that I am having with my earbuds. The right ear bud seems to have stopped working but it works when I twist the wire and I don’t want to have to twist it just to use it. Is there any way to fix this? I never dropped them and when not in use I put them in the carrying case. I had these earbuds since the end of January of this year.
Soundbuds Curve Help
They should still be in warranty if you purchased them from an authorized dealer. Send support an email and tell them about your issues, what trouble shooting you have tried, serial number and order number. They may not get back you until Monday. They tend to run a small staff on the weekends or may even be closed.
Alright thanks mate.
