Is there a way to disable the low battery sound on the Soundbud slim earphones? Fair enough, do it once, or flash the LED, whatever - but it happens too commonly for there to be no option to disable in my opinion
Soundbud Slim battery warning
Don’t think so.
But you might ask the support as well.
Unfortunately there is no way to turn the low battery warning off. Others have asked and support said no
Nope unfortunately not.
Best thing to do is try and get a sneaky top up charge in every now and then so you don’t have to worry about it
I thought that’d be the case. Thanks all for your responses
