Sound on left earpiece is very low
Hi, I recently purchased Anker soundcore Life P2 wireless earbuds from Amazon …after a days usage the left earpiece sounds very low as compared to the right one …is it normal or some problem with the product ?
You should contact support. Maybe it’s a defective unit
Is volume still low after a reset of the earbuds @musaddidob ?
I am facing the same issue, even after resetting. Should I call for a replacement?
