Sound core life note voice issue
Hi,
Purchased soundcore life note last week. I noticed that the caller is able to hear voice properly, it’s very faint. Is there an issue with the mic, should I replace the device ?
If you use the search function here (magnifier) you should
find similar inquiries and
there may be a satisfying solution.
Hmm contact support
The same issue.
Tried:
  1. resetting the earbuds
  2. connecting to different devices
  3. connecting left as the primary
  4. connecting just one earbud
Just two weeks of use.
So you have to contact the support.
