Hi,
My SoundBuds Sport wont turn on. I´ve tried to chrage them, but the red LED turns of after 2 min´s. I have tried to search on google with no luck - can you help?
Hi,
Try charging them using a different cable and plugging them into a computer or wall adapter. If you tried charging them with a battery pack most will not sustain the charge as it draws such little voltage the battery pack ends up turning off.
Thanks, but this solution is already tried… With no luck…
Hi @Jesper_Aamand_Enevol , if you have already tried as @elmo41683 as suggested, I would suggest you reach out to support@anker.com with your serial no, purchase date and troubleshooting steps taken so that you can get direct support and/or a replacement if you are within your 18 month warranty.
