Sound Buds Curve - Multipoint Pairing
I just bought a SoundBuds Curve Bluetooth headset and I have found that the “multipoint” pairing only seems to work for the ear buds and when I try to use the microphone, it doesn’t work. Can anyone confirm that they can pair this device with two phones or a phone and a PC and use the microphone on both devices? Thanks!
Based on your situation, for the multipoint pairing mode, be advised that you could press and hold the + and - buttons simultaneously for 3 seconds to enter multipoint pairing mode (With the first mobile device connected). Once multipoint pairing mode is entered, user can connect a second mobile device to Soundbuds Slim (The second device must be connected manually), but please note that the Anker Soundbuds Curve can only play music on one mobile device at a time.
If the issue still persists, don’t worry, please don’t hesitate to contact us at support@anker.com by detailing your order number and the problem you come across. We will reply you within 24 hours.
