After testing the Soundcore Liberty Neo I have concluded that it is possible for design and sound to go hand-in-hand. The case is the first sign that this is a premium product at an affordable price. It has a slight shimmering effect that more expensive competitors don’t even feature. The charging case also had a flat bottom to keep it from sliding around on any flat surface. The sound is superior to my Jabra Elite Sport and I appreciate the fact that they try to present songs as they were intended to sound versus adding extra filters and altering the music. The sound is very crisp and clear and there is no learning curve when first using them. They connect quickly and seamlessly to the iPhone and are ready to go after a quick charge.
Instagram – https://www.instagram.com/p/BuNIVTonuMV/
Twitter – https://twitter.com/NReluctant/status/1099112625110175745
What are your thoughts on them if you have had a chance to use them? I am extremely impressed.
