Hi! I’ve been using my liberty air for almost 3 months. And now the left bud is not working. I did reset it 5 times but still doesn’t have sound. I bought it at USA but now I went back home to Philippines. :—(
Souncore liberty air
What reset method did you try? There are two methods depending on when your liberty air were manufactured. Method one and method two.
Try whichever one you haven’t used yet, and let me know what happens
Hi there! I’ve tried doing those resetting steps (both 1 and 2) but still the left but has no sound.
You might get more traction on the soundcore collective. Go here to sign up!
Very strange. Next check the charging receptacles on both the left bud, and the left charging case slot. Check them for any dirt or lint etc. that could be preventing them from charging properly.
If all else fails you can contact soundcore support at service@soundcore.com
P.s if you hit the direct reply button at the bottom of the message, it will ensure a faster response
Sorry, I’m not sure what you’re talking about. I remember you helping me out with the reset methods, but I already shared both of those.
@gAnkster referrals don’t work if the person already had an anker community account
The method I messaged you on the other forum, which is different than the two you posted
Lol I totally forgot about that. Here it is
Try putting them back into the case, press and hold down the control button until they turn off. Then remove the left earbud and then the right, if they dont turn on tap and hold the control on left first and then repeat for the right. Once they connect to eachother try to pair to your phone
Good luck!
