Hello eveyrone,
I come to you today with a question. I have been used to iPhones for the past 10 years, and my recent switch to Android has raised an issue. I just found out a few days ago, while testing my SoundBuds Lite and Curve.
With iOS, a double-press on “PLAY” would skip to next song, and a triple-press would go back to the previous one.
I tried with my OnePlus 5 running Android 8.0, and these song controls are not supported. Do you know if it’s the normal behavior, or if it is supposed to work?
Thank you all for your help.
