[solved, how to inside) Nebula prizm II pro netflix issue (-13 -14)
edit: the support finally gave this link to show how installing a working version on netflix, it’s for capsule but work the same with prizm II pro
hello, i have issue with my brand new prizm II pro, Netflix is not working (issue 13 and 14), tried to update all apps, still not work.
trying reboot modem, not work.
uninstall/ reinstall, not work
tried even with chromecast: if i cast only the netflix tab from pc or netflix app from phone it load then crash.
if i cast my whole desktop it work but it’s laggy cause my nebula is far from router.
Grat on finding a solution.
Excellent job
