Solar Charger - Wrong Connector
Just Purchased 2 of the 4G Outdoor Starlight Cameras w/ Solar panels. The Camera requires a USB C but the Solar panel has a Micro USB. These are sold as a set but not compatible with each other. Anyone one else have this issue? Suggestions? Also, I’m assuming that if you use the solar panel the camera is no longer rated for outdoor use as the rubber seal will no longer close over the sim card & power port.
Hi. I’d recommend searching the Eufy community first. If you can’t find the answer there, reach out to support at support@anker.com
