Soft pouches for power banks?
Bought a new 10000 PD, looking for a soft pouch/skin to put in the same pocket as the phone. Would prefer of course to have the Slim 5000, but it doesn’t have PD, which is a priority. So looking for a solution to avoid scratching the phone with the power bank.
Any suggestions?
It should come with one!
All my Anker powerbanks came with soft cases
I’ve bought/given about 5 powerbanks and each one came with this pouch.
You could just put a skin on your phone to help protect it?
I’m a bit confused.?.?. Why didn’t it come with one?
both of my powerbanks came with a pouch.
are you sure you checked the whole box for it because its usually in there
Yeah all of mine came with one as well…
I am going to open my package tonight (yes, I’m excited :yum:) and see if they change any contents recently…
Yeah, they all come with pouches! They’re pretty awesome!
20100 I bought 2 weeks ago did not come with pouch and there is no space in package for it anyway. Only arrived with manual and cable. Last year when I ordered different one there was a pouch.
All of my Ankers have come with some kind of a pouch.
I’d be curious of a source for a replacement pouch should the pouch rip?
