Signal Issues
I have 4 outside cams, one inside, keypads, window sensors and a lot more. only started setting up camera with Hub 3-4 meters from the Outside Camera, yet as soon as it goes up, no signal. if it will not work at that distance, all other cameras will have no chance, let along all the internals. if i cannot get a signal, everything is useless, help!!!
Chances are you’re putting it near metal which is blocking the signal. Try moving it a few inches either side.
Try moving the camera a little.
Try moving the homebase also to be not near any metal (such as wires in the walls) and/or get it nearer to the camera.
Did any of this work?
