What can I do about side brushes that keep falling off?
Side brushes
After removing the brushes you see a screw on top.
Unscrew and take off that “metal clamp”.
Then bend this a little more ouside to give the brushes a better hold.
You see the screw and the clamp (dismantled motor))
Thanks, Chiquinho! I’ll try that!
