Have (or should I say had?) a Soundcore Boost bluetooth speaker. Lovely thing. Nice design, good sound. It was dropped once (seriously only once) from about waist height and has never worked correctly again. Battery life instantly was cut in half. It goes from 4 dots to 2 on the charge scale immediately after full charging. The battery life was never great but now is less than two hours at moderate volume. Secondly, if the bass boost is engaged (or if the volume is turned up) the speaker goes “zzzzttt!” loudly and shuts itself off. Interestingly it will turn back on immediately when the power button is pressed.
Has anyone else had these problems? Is a repair possible? Thanks
