Short/thin USB-C cables?
does Anker make anything less than 3ft? I lost the one that Anker included with my 30w USB-C wall charger and would like to have a replacement.
I find many of their cables very thick and not too travel-friendly.
I could use both USB-C to USB-C and USC-C to USB-A, maybe 18" long?
For small cables in length they make 3ft 1ft and 4inches.
I wouldn’t say they are flat cables more like you typical nice Anker cables and they are nice and travel friendly. Depending on they type of cable you get some of the 3ft cables come with carrying cases to make organizing the cables better. Not sure if they make small ones for usb c yet. I could be wrong though.
Hope this helps
They have pre owned 4 inch lightning on sale for a discount:
Not what you’re looking for, I know, but others might!
May be some very short ones would be good not only when travelling.
I always wire long ones.
Anker do a short USBC, the catch, you have to buy the multy pack to get it. It’s part of the 5 pack of leads.
I’ve asked several times, and previously Anker said they don’t intend to make it a solo lead.
It’s a shame, esp now they make more USBC powerbanks, and no one wants a 6ft cable to use a powerbank in their pocket. None of the powerbamks come with a USBC lead, not even the ones that are USBC charged.
Micro-usb charged PBs, get a lead
Even if they did a multipack of short usb leads would be better than not at all. I had to go to their comptetitor who make short braided usbc cables. I didn’t want to, but I had no other choice.
Obv Anker don’t want all my money… ¯\(ツ)
Yes I am with you.
Short cables NOT for traveling only.
I would like to see those also.
Waste of material!
Those who would like those short ones and are forced to use the long ones. :angry:
I can buy a pack of.cables and get some short ones?
I think monoprice makes .5 meter.
I bought Aukey 1ft. and they are very thin. liking these, I hope I can find similar in 3 ft.
A flat version of the USB C cable would be great.
anything that takes less room. need thinner for travel.
