Set up home base and modem troubles
Hi, I recently purchased a eufy cam 2 camera set.
I just recently tried to set the home base and as soon as I plugged the cable into the modem, the 2.4/5ghz light went off…
Has anyone ever had this problem? All of the modem lights are green. Nbn has no outages. Yes, I have tried Turning it on and off again.
I am stumped
My own view, it looks like a failed unit, unplug and get onto warranty immediately.
https://www.eufylife.com/contact
It is weekend now so assume a reply on Monday. All the support info shouts not weekends.
Thank you for your reply. I think you’re right the more I think about it.
Thanks
Tom
