Serial no Space Q45
Where I can find the serial no In the Space Q45 headphones. The website says its in the inner side of the headband but I couldn’t find it.
Thanks
May be its on the package as well.
You may want to shine a light on the band as well. I do find it is hard to see without it.
I usually get it in a good light source and take a photo of it. It make it easier to get all the numbers
I have some at home i’ll look later but from my Q30 experience it’s an almost invisible number in a faint brown colour on inside of the headband if you fully extend them. Or just have the original package. I photo original packaging anyway always.
