RE Anker USB C Hub for MacBook, PowerExpand Direct 7-in-2 USB C Adapter: which way up do I stick an SD card? It doesn’t want to go in but I am wary of forcing it.
SD card
It doesn’t have an icon displaying it? Just give it a little push
The contacts of the slot are normally at the bottom .
But take a look.
Being careful is important, otherwise you will ruin the pins.
Thank you, guys, for your speedy replies. It still doesn’t work so I’ll have to try another approach.
Best of luck dude
