Save $90 on Eufy Robovac G10 Hybrid, Deal for $209.99
eufy by Anker, RoboVac G10 Hybrid, Robotic Vacuum Cleaner, Smart Dynamic Navigation, 2-in-1 Sweep and mop, Wi-Fi, Super-Slim, 2000Pa Strong Suction, Quiet, Self-Charging, for Hard Floors Only
Buy here
Product description
1
The Same Clean in Half the Time!
Gyro navigation has up to 2x the efficiency of standard robotic vacuums. This means a clean which would take 100 minutes with bounce can be completed in 50 minutes with gyro.
3
Sweep. Mop. Sparkle.
2-in-1 sweeping and mopping will leave your floors crumb-free and squeaky clean.
4
Ultra-Thin Design
Super-slim 2.85” body effortlessly glides under furniture and into hard-to-reach areas.
5
Minimum Hassle, Maximum Convenience
The redesigned Unibody Filter increases efficiency and lasts longer which means less fuss for you.
6
Drop-sensing
Safe Upstairs
RoboVac uses drop-sensing technology to avoid falling down stairs and off of ledges.
7
Auto-Return Cleaning
When the battery level is too low to continue cleaning, RoboVac will automatically return to the charging base. Once charged to 80% battery it will resume cleaning in the area at which it stopped.
8
Disturbs Dust Not People
Advanced brushless motor significantly reduces vacuuming noise. Produces only 55dB of noise while in use - less than a microwave.
9
Pet-Proof Surface
Anti-scratch tempered glass-top cover for protection against curious pets.
RoboVac G10 Hybrid
Eliminate Vacuuming Chores
RoboVac takes on dust-busting around your home so you don’t have to. Multiple cleaning modes and auto-clean scheduling ensure an effortless, thorough clean while you relax.
Smarter Than Ever
RoboVac G10 Hybrid is undeniably a teacher’s pet. More intelligent, with Smart Dynamic Navigation,Wi-Fi and voice control.
Versatile Cleaning Made Easy
2-in-1 mopping and sweeping for a sparkling clean without the effort. Unibody filter for less maintenance and more relaxing.
Lean, Mean, Cleaning Machine
2000Pa of superior suction power ensures your home is clear of dirt, dust, and crumbs. RoboVac may be ultra-slim, but it’s packed with a 3-point cleaning system consisting of a suction inlet, and side-brush which deliver meticulous cleaning.
Cleans While You Relax
Refined from the inside out to provide quiet vacuuming with zero hassle. RoboVac cleans with the equivalent volume of a microwave, and is only 2.85” tall to clean under low-hanging furniture with ease.
Premium Components
The anti-scratch tempered glass cover provides a sleek look and superior protection for RoboVac, while the unibody filter achieves a better clean for your home.
Year-Round Support
At eufy, we believe in our products. That’s why we back them all with 12-month coverage and provide friendly, easy-to-reach support.
For Optimal Use:
  • Engineered for hard floors such as hardwood, tile or laminate etc. Note: for best results on carpets and rugs please check out our other eufy RoboVac models below.
  • Move cables out of the way to avoid tangling. 5 cable ties are provided to help you better organize wires and power cords.
  • Standard suction mode (hardwood floors) - up to 80 minutes of cleaning.
  • Max suction mode (medium-pile carpets) - up to 40 minutes of cleaning.
Great find @Shenoy
I like this purely for the dog riding the cleaner :dog:
Great deal! Thanks for sharing!
Great deal!
